I'm looking to buy a Catalina 22. But I'm confused about which keel would be best.
I live and will be sailing mostly in FL with lots of shallow water, so I think the fin keel is out.
So I'm left with the swing keel or the wing keel. I have to admit I'm pretty nervous about the swing keel because I will be leaving the boat in the water year round and ferrous metal and full time salt water don't seem to mix well.
The wing keel eliminates the rusting metal issue, and only ads 6" add'l draft.
I looked at a real nice swing keel at a good price but the keel already has some rust on it - even though the boat was trailer sailed exclusively in a fresh water lake.
I only plan to take the boat out of the water very rarely.
Can someone give some help as to why one is preferable over the other.
It seems that the wing keel doesn't have any of the maintenance issues of the swing keel and only adds 6" to the draft.
If I did buy the swing keel boat that I looked at how do you go about painting the keel while it is on the trailer? The rust seems to be fairly superficial at this point but I wouldn't want to put it in salt water full time without cover it with some sort of protection. Does it require that the keel be removed?
Thanks for your help.
