Which Bolt Bleeds the Yanmar Fuel Filter? 4JH4E thanks
Do not know. Engine manual should tell you; might be available on line - Page 244 Fuel Feed Pump; Construction Of Fuel Feed Pump; Fuel Feed Pump Specifications - Yanmar 3JH4E Service Manual [Page 244] | ManualsLib). In the past I've filled the new filter with fresh fuel before installing. Then used the primer lever on the pump to push more fuel into the filter and lift pump. Took but a few cranks and she (4JH2-TE) fired right up.Which Bolt Bleeds the Yanmar Fuel Filter? 4JH4E thanks
