Changing the oil:
I can only "suck-out" about 3qts of used oil thru the dipstick tube from my Yanmar 2QM20.
According to the manual it holds 5 qts. I have been using a Big blue Topsider manual pump to suck out the oil and it works ok if oil is warm. The pump's thin hard plastic tube end is bottoming out on the bottom of oil pan (thru dipstick tube) yet seems to leave approx 2 qts still in the engine.
How can I get the other 2 qts out of oil pan? (with no drain plug)
Thank you
Thank you
