where to start bottom paint?
8
Hunter 25.5 Dartmouth MA
We have a hunter 1984 25.5 it has nver had bottompaint as it was a fresh water boat. How do I find the water line? Do I paint to the boot stripe. I am going to apply a barrier coat and ablative anti- fouling paint. Thank You
Scott
I start mine at
I start my bottom paint right at the bottom of the boot stripe.
Mar 21, 2004
343
Hunter 25.5 Carlyle, IL
Barrier coat
The waterline on our 25.5 is a couple of inches below the boot stripe. I think it looks a little better to have a little gap between the boot stripe and start of the bottom paint.
Jim
Add some dimension
I think it is better looking if you add some visual dimension to the waterline by leaving some space between the bottom paint and the bootstripe. See photos on the attached link. Some look better than others, some look dull, some look fast! <G> See link Jim
Steve O.
below boot stripe
Kill two birds w/ 1 stone: Use the boot stripe to line up your masking tape, then your bottom paint will be the width of the tape below the stripe.
Jan 13, 2005
8
The transom
How about a line on th transom. Jim, your link was a grat help, but I don't know what to do at th transom? Also, Scott I looked for your boat at 2 Brownell's. Which yard is it at?
Scott
Brownell's
It's at the Mattapoisett yard that is right near exit 19. Beside's my 25.5 there is another that has a black bottom.
Jim
About the Transom Gib.............Jim
Gib, most sailboats have an overhang aft, but if not just continue the line around the transom as it flows parallel to the waterline , perhaps this image will help. In the case of an overhang, you would continue the line aft, down and under the hull and there would be no line on the actual transom. See attached image..........Jim
Jim
Ablative?
Gib, if you plan to bottom paint, you may want to think about a hard Trinidad finish, instead of ablative. In your area a Trinidad paint will last you many, many years. Ablative will build up, flake off in spots, and create an annual paint job/sanding task for you. If you use hard Trinidad paint, you'll only need to polish (light sand) the bottom to restore the antifouling properties (remove oxidation) each spring, and not have the ablative build up. If you use Trinidad hard paint, you likely wouldn't have to repaint for 6 years, just polish every spring and splash! Just a thought, look into Trinidad SR Gib.
