I believe it is in the bow near the windlass.If the windlass is an original factory or dealer installation, the solenoid control is probably in the engine compartment. On my 1997 model the windlass cables were run from the bow to the engine compartment where they were terminated. Apparently the factory intended for the windlass to be powered from the starting battery. Since my boat did not have the windlass installed (just the 2-0 cables to the bow, thank you Hunter!) I extended the cables to the cockpit aft lazarette and put my solenoid box in that location and used the house batteries for power.
This makes more sense. Less wiring, especially if the motor is a 3-wire unit.I believe it is in the bow near the windlass.
You can easilly verify this. Look where the footwswitch wiring leads
