Where does the sink drain??
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
Yup - I can’t say for sure that screen was the “only” problem, but I can’t imagine how ANY water was getting through it.
waaaaay more disgusting than swapping the joker valve!
Yes, clean the tanks as best you can but the screen may still need to be cleaned frequently! It absolutely affects the pump and can stop the flow of water. It's a regular maintenance item! (You'll get tired of lifting those cushions or mattress if you have one :huh:)
Oct 26, 2008
6,370
@Scott T-Bird
The Schafer was one of this mornings butt scratch moments.
It was actually way easier than rigging the roller curling on my C-18. The only ponder was that there are two tracks the bolt rope could go into. Same size, right next to each other.
After pondering a bit, I thought the dirty track was the one to use.
Then after we finished the install I thought the clean track must be the one that was used last, because bringing the sail down would essentially wipe it clean.
The double track enables you to raise a second headsail. I didn't even know if it was possible with a furler but it appears that there are a few techniques. Racers will use double tracks without a furler so they can make sail changes without lowering a sail first (bald-headed sail change).
With a furler, some cruisers may want to sail with twin headsails stretched out on both sides for a downwind run. One way is to hoist both sails with the upper furler. Another way (I read) is to attach a block with a halyard at the head of the 1st sail and raise the 2nd sail with the block at the head of the 1st sail. I've never seen anybody actually do this and it does seem that putting a twin track with a furler is just an unnecessary feature that nobody ever uses (I certainly haven't).
I don't think it matters which track you use but it would make a difference if you knew which side the 1st sail is going to be on if you decide to raise a 2nd sail!
Likes: john6206
Feb 19, 2008
480
Catalina 320 Tawas Bay Yacht Club
Thanks Scott,
I can’t work out the geometry of two headsails on the same furler.
I can see the “two jobs downwind” thing,
I guess that’s one thing I don’t need to worry about!
Thanks Scott,
Outside of the “twizzle rig” downwind with the two headsails on opposite sides, the other use like Scott said is just temporary while changing sails. I’ve crewed on boats that did that. They call it a “peel”, usually raising the new smaller headsail on the windward track when an overpowered sail is on the leeward track. The old sail stays sheeted in as the new sail is hoisted just inside it, so the shape is preserved. Once the new sail is at full hoist it gets sheeted in and the old sail dropped.
As you sail it’s something you don’t need to worry about. It’s probably just about as cheap for the furler companies to make the extrusion with two tracks as one, so they just make them that way and sell it as a feature.
Likes: john6206
Dec 2, 1997
9,005
- - LIttle Rock
Finally, exercise the valves monthly to keep them operating freely & lubricate them when you haul out in fall.
All thru-hulls should be closed when leaving the boat...some (notably any holding tank overboard discharge thru-hull) should be kept closed except when actually In use. A macerator or other overboard discharge pump cannot block water being pushed through that line into the tank, it can only slow it down.
And btw, there should also be a vented loop in the intake of a manual toilet. It does NOT go in the line between the thru-hull and the pump...it needs to be between the pump and the bowl, at least 6-8"above waterline AT MAX HEEL, not just when the boat is at rest, which on most monohull sailiboats puts it 2-3 FEET above the toilet bowl.This requires replacing the short piece of hose the toilet mfr used to connect them with hoses long enough put the loop where it belongs. Boat builders, who are the WORST sanitation plumbers on the planet sometimes put them under the vanity, which makes them useless.
Most toilet owner manuals include a drawing showing the correct vented loop installation.
Why do you need a vented loop in manual toilet intake? The toilet is below the waterline on most sailboats...a correctly installed loop prevents water outside the boat from finding its own level INside the boat when the intake thru-hull is open, making it unnecessary to open and close that one every time the toilet is used.
--Peggie
