The jib fair-lead is located so when the jib line is tightened it rubs against the gunwale. Where should I relocate it?
The boat was on land that day. I wrapped the lines around the winch to get them out of the way.]In your picture it looks like the sheet is wrapped numerous times around the winch and then tied off in front of it... is that how you secure your sheet? That is a dangerous way to manage your sheets. You should be quite effective with 3 to 5 wraps... then lead th sheet to a cleat... the tail is coiled and stowed neatly...
Why do you have so many wraps on that winch? This could be your problem.The jib fair-lead is located so when the jib line is tightened it rubs against the gunwale. Where should I relocate it?
My son just gave me a piece of 1" thick PVC foam board and I'm contemplating on using it to make a Mickey Mouse mast extrusion.Joe,
My originals were teak and worn out so I made new ones out of the PVC lumber that I used for everything else. This pic is from before I drilled the mounting holes or the (forestner bit) recessed holes for the screw heads.
I like the clam cleat idea better but they're already on the boat.....
