Where do I get some of these rubber feet stoppers? (pic)
39
- - Lexington, KY
They're my ladder's rubber stoppers that protect the boat when the ladder is down. Haven't been able to find these possibly because I'm calling them by the wrong name? I wouldn't think they would only be sold at sailboat supply places; would probably be cheaper elsewhere. Thanks so much for the help.
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
I buy mine at Lowes or Home Depot. I think they are called rubber chair feet, but they work fine.
Jun 1, 2004
243
Hunter 26 Lake Pueblo Colorado
I just got mine at Home Depot, Rubber Chair feet, 1" Nornally need to replace them every second season.
Feb 10, 2004
4,226
Hunter 40.5 Warwick, RI
Be sure to measure, these are available in a couple sizes.
They are about $3 for a package of four.
Beneteau 323 Annapolis MD
Instead of just the ladder's tube pressing on the rubber foot, put a washer in the foot so as to increase the bearing surface of the stainless tube.
Oct 18, 2007
707
Macgregor 26S Lucama, NC
If you don't find what you need in the rubber chair feet, look in health supplies for replacement rubber feet for walkers and canes- they may be a little tougher for outdoor use. -Paul
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Pretty sure they are 1" for the 27. Definitely by them at a hardware store, I made the mistake of buying the "marine" version at West Marine for a high price, they lasted about half the season and dried out and disintegrated. The next set I got at a Home Depot and they've lasted a few years, I only had to replace one cause it fell off!
Manny
Ross
Jun 15, 2004
14,693
Crutch tips, cane ends and walker feet. Drugstores. best source.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Standard crutch feet would also work, but would be a bit larger and heavier...but far more durable. Using the washer as an insert helps a lot too.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
To add to the info, I use a couple of turns of white self vulcanizing rigging tape to hold mine in place so they don't drop off.
Have Fun
Joe S
Dec 3, 2003
544
None None Rochester, NY
I got mine at Home Depot, but instead of the rubber feet, I bought the plastic ones. They don't crack like the ruber and last much longer.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Thanks for the tips guys. When I bought my boat it had marks in the transom already from the ladder. I replaced the rubber feet last year and they are pretty bad already. I will try the washers, but another tip from the medical side of things is to use tennis balls (cut a slit and slip them on)...they used they all the time on the feet of walkers (Wife's a PT)...but your boat will look a little funny ;-)
