In other thread I saw a couple of sposts stating that a sailing vessel should be considered a power driven vessel if the engine is running, whether or not the transmission is in gear. So...who agrees, who disagrees, and why?
No, you remain a sailboat and more to the point of the original question, you light your boat like a sailboat so that other boaters understand your sail-driven motion and maneuverability.Per COLREGS,
The term "sailing vessel" means any vessel under sail provided that propelling machinery, if fitted, is not being used
Not wanting to come across as a sea lawyer, if you're running the engine solely for the purposes of charging the batteries, does that count as use?
Benny, good points. A couple of weeks ago, I was out sailing - port tack. A sailboat approached me from starboard, starboard tack, under full sail. I fell off to honor his starboard tack. As I crossed under his stern, I discovered that he had his outboard engine running and in the water. I was not amused to have given way to a sailboat under sail AND power. He clearly did not behave as a powered vessel.Whether the tranny and prop shaft is engaged or not is likely irrelevant. If the engine is On and the boat is moving it would be a hard case to make that the boat is not being operated under power. If exhaust smoke and sound confer to others the idea that the boat is being powered then you are a power boat in their eyes and you will be expected to behave as such. I have encountered instances during motor sailing where other boats have deferred to me as a vessel under sail because they probably could not have observed my engine was running. Such actions just add to safety but they do not relieve me of the responsibility of behaving as a powered vessel. In case of an accident a court of law will make the determination whether the boat was powered vessel or not.
Amen, brother! Peace.You REALLY wouldn't have been amused if you had collided, right-of-way or not. If you observe a pending collision and do nothing because you "have the right-of-way" you will be found partially at fault, and bear liability. The point of these rules is to better ensure accident-free boating, not to help you win an argument.
If you're "behaving as a power-driven" sailing vessel during daylight with your sails up and drawing, you should have hoisted the appropriate day shape that communicates your status. That is your first responsibility; not to maneuver as a power-driven vessel that depends on the other guy detecting exhaust or water discharge to learn your status and anticipate your maneuvers.Whether the tranny and prop shaft is engaged or not is likely irrelevant. If the engine is On and the boat is moving it would be a hard case to make that the boat is not being operated under power. If exhaust smoke and sound confer to others the idea that the boat is being powered then you are a power boat in their eyes and you will be expected to behave as such. I have encountered instances during motor sailing where other boats have deferred to me as a vessel under sail because they probably could not have observed my engine was running. Such actions just add to safety but they do not relieve me of the responsibility of behaving as a powered vessel. In case of an accident a court of law will make the determination whether the boat was powered vessel or not.
Not so. The law refers to "power-driven" when defining the difference between sail and power, and relevant lighting schemes. The law says nothing about the engine running. If your sailboat isn't being propelled by a motor you are not "under power". And it is important to understand this, because sailboats under power can be anticipated to behave differently than under sail. And that is the entire point of the COLREGS lighting requirements.the law says if the engine is running and we are not tied stationary to something, we are considered to be "under power".
im not taking this out of concept, as i have read your entire post, but it seems that unless someone posts the actual law as its written in the law books, here, everyone will continue to have their own idea of what the facts are, BECAUSE there are so many places on the internet that have a bit different interpretations posted by authoritative people....In point of fact, if your propelling machinery is not engaged in motivating the vessel, you are NOT under power. If your engine is running, to charge batteries, or for any other reason, but NOT propelling the vessel, then you are NOT a motor vessel.
which kind of lends to support to what I had posted earlier....This is from the BoatUS website:
Vessel Types
•Power Driven Vessel - Any vessel propelled by machinery. This includes any boat that has an engine. Sailboats are considered powerboats when they have the engines on--even if the sails are up.
•Sailing Vessel - Any vessel under sail alone. Remember, the engine only has to be on for a sailboat to be considered a powerboat.
http://www.boatus.org/guide/navigation_2.html
