When are you a "power driven vessel"?
capta
Jun 4, 2009
4,906
im not taking this out of concept, as i have read your entire post, but it seems that unless someone posts the actual law as its written in the law books, here, everyone will continue to have their own idea of what the facts are, BECAUSE there are so many places on the internet that have a bit different interpretations posted by authoritative people....
im not sure that this is the explanation of the actual law as it is written in the books, or just someone elses interpretation, but I have personally this read in a marine "rules of the road" manual, that regardless of why the engine is running, if you are under way and the engine is running, you are considered to be under power. period.
the explanation given there was was because its assumed by the law that so many people will be tempted to engage the transmission when the engine is running and charging batteries so that they can take advantage of the otherwise wasted power, and in addition, with the engine running, you have the ability to out maneuver and better avoid conflict with the other vessel at the shift of a lever.
and it may also be assumed by the law, that if there is an accident with a motor sailing vessel and a non motor sailing vessel, any argument that is given as to whether the yacht was actually under power cannot have the excuse that it was only running the generator and not actually in gear...
it is a fine line between "what it is" and "what it appears to be".... I think the reasoning here is to take any excuses or temptations out of the equation.
but none of this makes a difference or care unless you are situation where there is a close call and you are either the cause of it, or you take the advantage at someone elses expense, and it is found that your engine was running and available to prevent the situation...
You only need concern yourself with three words in the rules. These three words leave absolutely no room for interpretation.
"PROPELLED BY MACHINERY"
Jun 11, 2011
1,243
Hunter 41 Lewes
In point of fact, if your propelling machinery is not engaged in motivating the vessel, you are NOT under power. If your engine is running, to charge batteries, or for any other reason, but NOT propelling the vessel, then you are NOT a motor vessel. If your sails are down and your engine is on, but not engaged in propelling the vessel, then you are a vessel not under command, which is a completely different set of lights. Many cruisers will run their engine out of gear, while under sail to charge batteries, run watermakers or refrigeration, but they are still being propelled by their sails and therefor should be lit as a sailboat. It's all about what is making the boat go, and the expected maneuverability of the vessel, under the rules.
Not under command is for a vessel that has a disability that renders it unable to make way in a controlled manner. If you lost your rudder you would be not under command. Being propelled by machinery is the only time you are a "power boat", in that respect you are exactly correct.
The big issue here is that you are all assuming that the other boat KNOWS the RULES. You should all be helming as if no one else has a clue about the rules wether you are a sail or power boater. If they did they would make their intentions know early enough as to have no doubt that they understand the rules and the situation, as you should do when helming.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I was one of the people talking about this in the other thread and thought I would state my opinion here as well.
Under the Colregs, a boat with the engine running but in neutral is considered a power-driven vessel. This is because your engines are available for immediate maneuvering. The example that was used in my captain's class and was on my test is a power boat in neutral drifting. This vessel would be the stand on or give way based on it's position in the pecking order and its position relative to other vessels.
So if a group of guys are fishing off of a 45 foot power boat and they have the engines on but are drifting while they cast lines and another power boat is approaching them from their starboard, the guys fishing are obligated to put their engines in gear and get out of the way.
The same holds for sailboats with the sails up and engine on in neutral. You can engage your engine since it is on and available for immediate maneuvering.
You can argue about the other guy being able to see your exhaust or propeller or what ever but if an incident occurs and you had your engine running and you didn't act as a power-driven vessel you will very likely be found at fault.
As others have mentioned there is a day marker, cone with the apex pointed down, that you should be displaying if you have your sails up and engine on during the day to signal to other boaters what your designation is (i.e. a power-driven vessel). At night you would do this by turning on your steaming light.
Good luck and fair winds,
Jesse
May 4, 2005
4,062
I'd like to see the exact law. everything I read is a repost or interpretation of USCG rules of road.
While engines may be running, there is no way we would engage the transmission, during a race, because that would be a disqualification.
I don't see how any court of law would consider a racing sailboat a powered vessel.
it doesn't pass the smell test.
-that said, we always follow the tonnage rule.
Beneteau 323 Annapolis MD
I'd like to see the exact law. everything I read is a repost or interpretation of USCG rules of road....
# 23 gave us a synopsis of the colregs, but, yeah, I'd rather see a cut-and-paste posting of the rule. Ted helps, but not sure those are his words, or are word-for-word.
It always amazes me when people, like the OP, ask a question that should be answered by looking up the governing rules/laws. OPINIONS are no good when you try to defend your actions in court.
capta
Jun 4, 2009
4,906
Not under command is for a vessel that has a disability that renders it unable to make way in a controlled manner. If you lost your rudder you would be not under command. .
This is certainly one use for NOC, but when I was single handing and needed extended sleep, I would bring down the gear and run the NUC lights. You do not need to be disabled to be 'not under command', just not under command.
Gunni
Mar 16, 2010
5,937
What amazes me are the number of so-called vessel instructors who don't know the COLREGS, or the simple definition of power vs. sailing vessels. Makes me wonder who is running the training programs or writing the tests. Way to much confusion, starting at the head of the classrooms.
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
From the CPLREGS:
(a) The word “vessel” includes every description of water craft, including nondisplacement craft, WIG craft and seaplanes, used or capable of being used as a means of transportation on water.
(b) The term “power-driven vessel” means any vessel propelled by machinery.
(c) The term “sailing vessel” means any vessel under sail provided that propelling machinery, if fitted, is not being used.
Seems a lawyer could argue it either way. My opinion is engine on - I'm a powerboat
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
You can become an instructor, typically, with a demonstration of knowledge/competence of 70% of the material. It's a pass/fail situation. Few would ever make it at 100% competence if needed to "pass." Remember the old joke--What do they call the guy who finishes at the bottom of his class at medical school? Doctor!:eek: Maybe you've run into some of 'em!
Oct 13, 2013
182
Wayfarer Mark I GRP Chicago
Everything I have read in any of my studies state that if the engine is running regardless if it is being used for propulsion you are considered a vessel under power.
Gunni
Mar 16, 2010
5,937
I would expect that "power-driven" and "propelling machinery" would be clearly explained to note for students that the terms "engine running" were excluded from the definition of a powered vessel. And maybe, why that distinction is important to the practice of sailboating.
Nov 18, 2010
2,441
We had 4 different instructors when we took our captain's license classes. One was the owner of the school. One instructor was great. He had an unbelievable grasp of the subjects, knew when situations like this were not fulled explained in the COLREGS and expanded on it, covered the material very well. He had been teaching the course for over 20 years, tons of real world experience and was a general good guy. The owner was pretty good as well.
Two of the instructors were absolutely horrible. The didn't know the info. Just read from the books. Confused people on a number of points because they were wrong. At one point I actually got up and my wife and I walked out because he was starting to confuse us on points we already knew because he was presenting it wrong.
So I agree with you completely. It seems like they will certify almost anyone to teach the course.
Nov 18, 2010
2,441
Racing in no way alleviates you from the responsibilities of the COLREGS. If you refused to engage your engine or take other actions necessary to avoid a collision you would absolutely be found at fault.
Jul 27, 2011
5,134
Actually--not always true. If you're sailboat racing and you have a crossing situation with a vessel that's not part of the race, then COLREGS would apply. However, if you're racing and a situation arises involving another boat in the same race, then the RRS applies- "The Racing Rules of Sailing." This is b/c parties to the race have agreed to following THOSE rules as a condition of racing. Evidently, a court case or two has supported that concept.
Gunni
Mar 16, 2010
5,937
A long-held concern that people don't know the COLREGS has now morphed into an even greater concern that people who actually "study" the rules are confused by what they "state". What study materials are you referencing?
Nov 18, 2010
2,441
Here is the PDF of the COLREGS. Take a read through the 226 pages. But good luck trying to interpret everything without any guidance.
As to some of the definitions that are being discussed:
RULE 3
General Definitions
For the purpose of these Rules, except where the context otherwise requires:
(d) The term “vessel engaged in fishing” means any vessel fishing with nets, lines, trawls or other fishing apparatus which restrict maneuverability, but does not include a vessel fishing with trolling lines or other fishing apparatus which do not restrict maneuverability.
(e) The word “seaplane” includes any aircraft designed to maneuver on the water.
(f) The term “vessel not under command” means a vessel which through some exceptional circumstance is unable to maneuver as required by these Rules and is therefore unable to keep out of the way of another vessel.
So to the poster who said they call themselves a vessel not under command when then go to take a nap while sailing solo, good luck defending that in court if anything ever happens. There is plenty of case law that has cited solo sailors for failure to maintain a proper lookout. And you don't meet the definition of the rules.
Here are two words you will find nowhere in the COLREGS: neutral; transmission. There is discussion of underway, not making way but that is only related to lights and day shapes.
If you are moving through the water you are underway. If your engine is running while underway you are a power-driven vessel. If you are a sailboat and your engine is off and sails are hoisted, you are a sailing vessel.
Nov 18, 2010
2,441
I would like to see some citations for this because a quick google search shows otherwise. From just looking at a couple of regulations you see statements like:
A Protest may be made by the captain/master of a vessel against another
competitor where it is believed that a rule infringement, or a violation of the
COLREGS, has taken place.
A proven breach of the COLREGS will be construed as unfair sailing and
may result in disqualification or Standard Time Penalty
Races should be conducted in compliance with the Sail Training
International Group Racing and Sailing Rules and the COLREGS
whenever it is appropriate for these rules and regulations to be applied.
Jul 27, 2011
5,134
Anyone could argue that the phrase "not being used" means "not being used [for propulsion.]" That's clearly implied. If a sailboater lost his propeller or bent his prop shaft in going from point a to b, and sailed into a harbor with the engine running in neutral to maintain battery charge, it would be ludicrous to argue that he was a "power-driven vessel" b/c his engine was idling.
Nov 18, 2010
2,441
Sure, if your gear was damaged in someway I am sure you would have a case that you didn't act as a power driven vessel. But simply because you refuse to put it in gear is not going to hold up.
Kermit
Jul 31, 2010
5,669
I find this thread pretty interesting. Everyone knows he is right. All I know to be true is that everyone is obligated to do everything possible to avoid a collision. Hmmm. I guess I now fall into the category of "knowing he is right."
We had a horrible collision involving death on a nearby lake at night. Public opinion has already convicted the speeding bass boat after midnight. We also had a case on a non-local lake that involved death of a waterskier after dark. My next door neighbors and their friends were convicted by local-to-the-lake-opinion because of their incomes. Crazy stuff.
