This forum has been a big help to me with every question I've asked so far. Why not push the limit????? I have a 1984 O"Day fixed keel boat. I have a 1996 Furlex Type B II furling system. It's old, but still works fine. My furling has a lot of play in it (guessing 2-3 inches total sway when furled at dock). Want to be able to point higher during my ocassional races (sails are new 2019). My backstay has been adjusted to the point of 2X the official factory suggested rake. The Furlex system does not have a turnbuckle on the forestay for fine turning adjustment, but rather relies on a set, hard non-adjustable length. Backstay is only adjustment, and it is maxed out.
Now you know my set up. Here is the question. IF I take apart a 1996 furler, I'm sure to break something. Replacement parts are no longer available. Thinking out of the box.......can I go to the "other end" of the forestay (top) cut off the terminal eye fitting, shorten the forestay and re-swege a new terminal eye fitting on. I would then have a shorter forestay , pulling the mast forward with a "harder tensioned" forestay. Less furler sway. Higher pointing. Happier me. Am I a genius, or an idiot?
