The holes are worn on the bottom of my mast on my '74 Catalina 22. The plan is to cut an inch off the bottom, gain that inch back with a 1" thick shim between the mast step and the deck. There is also a bevel cut on the bottom of the mast that I will need to re-cut so the mast pivots aft when I'm stepping it.
What is the best way to cut the mast?
I want to be very accurate so the cut is square. The bevel cut is going to be challenging given the angle. I would rather not use a hand hacksaw or reciprocating saw. I've been looking into a compact band-saw for the job but would unfortunately only need it for these couple of cuts. I've ruled out welding of any sort since that's more of a band-aid. Any help, direction, experience that you can share would be great.
THANKS IN ADVANCE. - Paul
