what would you do? sailing off dock w/ no engine
JRacer
Aug 9, 2011
1,333
You might find it helpful to practice a "starting line maneuver" out in the lake where you have plenty of clearance. Stop the boat head to wind or just off to port with the sails flogging then ease in the sails to get the boat to move forward while not slipping to the leeward. Practice the maneuver until you can get the boat off a dead stop and moving forward comfortably in as short a distance as possible. Once you master that, coming off that dock with a headwind should be a well practiced maneuver.
1,320
Rob Legg RL24 Chain O'Lakes
for all the "buy a motor" people: I have one. It stopped working, and I haven't worked out why yet, mostly because I'd rather spend a day off sailing than futzing with a two-stroke.
Electric motors start every time you flip the switch. For that boat, 86 lbs thrust is probably reasonable. 400 bucks for the complete setup.
How are your sails? You are not going to sail up wind without good sails.
Jun 9, 2008
1,771
- -- -Bayfield
The first thing you want to do is drop the swing keel or centerboard. If that is not down, you will slide sideways and have no or little windward progress. The O'Day 222's mainsail is big, as you pointed out and so should be fairly balanced by itself, but you will have better windward performance if you use the right size headsail for the wind conditions. Based on your drawing you should be able to put the sails up without the wind having much affect on them (let them flog) and then you can climb on board fall off, trim the sails to close hauled and sail away from the dock. If you put the at the end of the dock so you have a beam reach, you will not have as much control and you might not get enough boat speed up so that you can tack before you start mowing down docks. In your drawing, your boat is nearly at a port close reach with the winds coming from where they are and so you can hop on, trim your sails and sail out into the lake on a port tack. If you happen to start sliding to starboard on your port tack, putting you at risk to hit the docks, then you can tack away to starboard. Just remember you have to establish some boat speed in order to tack. So, when you let go of the dock the first thing you need to do is get some boat speed going even if you are heading toward disaster. With boat speed you can quickly tack and avoid disaster. After tacking onto to starboard you will be home free and will be able to just sail out into the lake.
Nov 26, 2012
1,653
Hunter 34 Berkeley
You gotta have the jib up for that one. You cannot point high enough under main alone. It looks like you could head off on a port tack and stay out of the shallows long enough to het some speed and then tack over to a starboard. You gotta have quick and clean tacks though.
May 4, 2005
4,062
How about tightening the sheets while still tied to the dock? release and you're already powered up.
but seriously an electric motor, battery and a solar charger will make your life better. GL!
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
Remember if wind blowing straight in towards dock when you leave for days sail it will shift and blow you off dock for return trip.
MitchM
Jan 20, 2005
1,022
read some of lin and larry pardy's books about their 'sculling oar' which fits onto their transom. using it gets them in and out of difficult harbors with all sails down... it would be fine on your boat.
