What will help a hatch that is difficult to slide?
Stephanie
I am a new owner of a used boat, and just recently, I noticed that the plexiglass hatch is difficult to slide - is there something I can do to that will ease the sliding? Thanks
K
Ken
Silicone spray
I used silocone spray on mine and it works fine. It won't attract any dust. You can buy it at most hardware stores.
C
Chris
Depending on how old it is
the slider may have picked up gel coat deposits from years of sliding back and forth. I removed my slider and carefully scraped off the white deposits, followed by sanding with wet or dry 440 and then 800 and finally compound. Use a small block so as not to mar the surface where it is visible. When all clean, a good spray with silicone as stated previously will help.
Feb 10, 2004
4,248
Hunter 40.5 Warwick, RI
I had the same issue only when the hatch was hot
Normally it was fine, but in the heat of the summer it would bind to the point I considered it a safety hazard. This spring I removed the slider and used a router to take about 1/16" off each side. No lube but it slides very easily now. The fit is not a precision requirement. An extra 1/8" of slop when cold is not a big deal.
Oct 26, 2005
116
Oday 28 Detroit/Grosse Pointe Park (O'Day 192, O'Day 28)
Maybe this teflon tape
http://www.layline.com/prodinfo.asp?number=JTT Japanese Teflon Tape Imported all the way from Japan, this tape is great to use around your centerboard or daggerboard to keep it from slopping around. It has a sticky back on one side and a very smooth, slippery feel on the other. Sold by the foot. I haven't tried it yet, but was going to get some for my hatch. If you get it before me, let me know how it works, and I'll do the same. Kevin
Jun 12, 2004
26
Aloha Yachts Aloha 27 Barrachois Harbour (Tatamagouche) NS Canada
ArmorAll™
We've had good results using ArmorAll on the sliders. About 10 seconds every couple of months gets 'em slidy again! Steve, Patti and Grace (Ship's Cat) sv "Ever After" Barrachois Harbour (Tatamagouche) NS Canada
