What to Look For in Buying
Roger
I'm about the buy a 1985 Catalina 30. I'm a longtime Cat 27 owner and this means learning new things. What do you recommend I look for during the survey. Are there areas in the 30 that need special attention. This boat has wooden spreaders (do I change them?) Any suggestions from you 30 owners would be appreciated. B91585@aol.com
Dave
Survey?
Hi Roger: No offense meant, but the fact that you have to ask that question tells me you need a professional survey. In my area they charge about $10 a ft and it is worth every penny. With all that being said, I would think the biggest thing is bottom blisters, make sure the bottom is clean and blister free. The overall cleanliness of the boat tells you a great deal about how the previous owner cared for their boat. Does everything work? Check every faucet, fan, light, pump, hatch and switch. A clean dry bilge speaks volumes of the care that boat has had. All boats do NOT have water in their bilge. Is the engine clean and are all connections tight? How is the running rigging? How is the standing rigging? Manufacturers recommend replacing every 10 years or so, if yours is original, it is over 15 years old. How many hours on the engine? How old are the batteries, do the cushions smell musty? Can you smell diesel in the cabin? (You shouldn't.) Not all boats will be perfect, but the above mentioned items make great negotiating points. good luck, Dave S/V Westwind
Jerry Maisonneuve
Wooden spreaders
I am just now replacing the wooden spreaders on my '84 Catalina 30 with the aluminum ones provided by the factory. The wooden ones have served well, but I don't want the continued maintenance. The factory kit has a compression sleeve which is supposed to go inside the mast and no one seems to have a clue on how to install this sleeve. If this can be done I would suggest you install this kit the next time the mast is unstepped.
