Don't ever use a 0 degree nozzle on fiberglass, even if it spins. You will end up with lots of divits. I usually use a 25 degree nozzle. It can cause damage to wood, fiberglass and bedding compound. I did some damage to a backyard deck once and had to "sand" the entire thing with the power washer to make it all match. Power washers are great but they must be used with great care on boat decks
