Hi folks, getting ready to run the coax and wire up the mast.
The coax is easy.
What sized wire would you use to make a run 35 feet from the breaker to the top of the mast for the LED anchor light and about 25 feet for the two LED spreader lights? None of the three lights use many amps.
Would you use stranded or solid wire?
Thanks in advance.
Jack
The coax is easy.
Thanks in advance.
Jack
