What size wire????
694
Oday 22 Hickory, NC
Hi folks, getting ready to run the coax and wire up the mast.
The coax is easy.
What sized wire would you use to make a run 35 feet from the breaker to the top of the mast for the LED anchor light and about 25 feet for the two LED spreader lights? None of the three lights use many amps.
Would you use stranded or solid wire?
Thanks in advance.
Jack
Jun 6, 2006
6,990
Wire type and coax size
Use stranded, tinned wire.
VHF frequencies are not very happy in small coax. It is recommended that for VHF freqs us use the largest diameter coax you can afford. 1/2" is about the smallest you should use.
good luck
Dec 9, 2006
694
Oday 22 Hickory, NC
Bill, where would I find Coax that large...I have not seen any that large?
Most I see is the RG8X that the truckers use that is about 1/4 inch thick.
Thanks.
Jack
11,760
Thanks.
Jack
Ancor and others make RG8U which is what I use. My boat came with RG58 and the difference in performance is fairly drastic.
Dec 5, 2003
204
Hunter 420 Punta Gorda, FL
LED lamps won't take much 18 -20 gauge would work. For the coax RG-8 is best then RG-8X.. Just make sure that you ask for a radio check every couple of hours, that's why I hate to turn on the the VHF.
Beneteau 323 Annapolis MD
The coax is easy.
Thanks in advance.
Jack
Tinned and stranded wire. Look in the West catalog advisor for proper the guage-for-distance and amps.
