What Modifications have you made?
Coyote
Sep 30, 2008
132
Hunter 30T Madeira Beach, Florida
While I spent a fair bit of time in my Captain's Berth (Quarter Berth) last week with my Battery Charger change and relocation, I had plenty of time to admire the ADDITIONAL opening port that the previous owner had installed.
This UPGRADE adds an amazing amount of light and ventilation to the darkest, and most air stagnant portion of our cabin.
which lead me to the question, What modifications or upgrades have you made to your Oday, that you think make it special, unique, etc....???
and YES! I know the is a special section of SBO dedicated to this subject, HOWEVER for the 28's there are ZERO entries,, for 272 there are MINUS 1, how is that possible,, anyway,
I offer my additional opening port as my entry!
Images attached,
Cheers,
Coyote
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Thanks for posting this, it's great stuff! I do want to add that the number of entries in the mods section stays at zero when people post their work in the forum.
Also, the chances of finding this mod later, when someone really needs it, is much lower in a forum search.
Don't get me wrong, we love documented mods any way we can get them but you could also post it to the mods section and get the ball rolling. ;)
Coyote
Sep 30, 2008
132
Thank you sir!!!
and an opportunity to Thank You and your team for providing an EXCEPTIONAL RESOURCE to an appreciative community,,,
I mention your site(s) to EVERY owner I discuss upgrades and modifications with, and in all honesty, would probably NOT purchase a sailboat, that did not have an active forum for support and knowledge,,
as suggested, article submitted for your approval under Owner Modifications,,
cheers,
Coyote
Mar 20, 2012
3,983
all I can find is "search owner modifications"... Im not sure where to find the link for posting to it, or browsing...
so what if I want to browse the modifcations?.... maybe by boat brand or length of boat rather than by owner, is there a way to do that or do I need to search for a particular owner to see only his work?...
Nov 8, 2010
11,386
Adding those opening ports to 'aft staterooms' on smaller boat does indeed at a lot of light and ventilation. Nice mod!
I find it interesting that they installed it in-side out. Those latching dogs look like they are just dying to get kicked and snapped off!
Coyote
Sep 30, 2008
132
Actually, never an issue with regard to the latches,,,
with the cockpit cushions in place, you clear the cushion, you clear the latch,,,
they probably could have installed smaller dogs, the window really has no real exposure to waves and weather,,
it makes a huge difference with regard to light and air circulation,
cheers,
Coyote
Coyote
Sep 30, 2008
132
Centerline:
since no one else has clarified this for you. I'll give it a shot --
If you click on "Boat Info", below the main header,,"OdayOwners.com"
then go to "Owner Modifications", then pick a boat size or model, click on that specific boat, then at the top of that section, you will see "Submit an Article", on whatever model you selected -- pretty straight forward,
and I imagine it's the same for each SBO Owners Group,,
hope that helps,
cheers,
Coyote
Mar 20, 2012
3,983
Centerline:
hope that helps,
cheers,
Coyote
Thanks Coyote... ill give it a try when I get back on my pc..
May 16, 2011
140
Oday 28 Niceville, FL
I've posted alot of things on these forums over the years. My boat is heavily modified and I'm int he process of completely redoing the electrical, galley and refrigeration.
Many mods were done before I got the boat but I've improved upon many of them.
  • Traveler moved over the companionway.
  • Full Bimini and Dodger.
  • Repowered to Yanmar 2GM20F
  • Campbell Sailor prop.
  • Air Conditioning.
  • 230W 24v Solar power with 4 T105 house bank.
  • Customer LED lighting throughout.
  • Teak Hand rails removed and replaced with Stainless steel set up.
  • Deck organizers replaced and repositioned.
  • Hatch slides replaced with PVC.
  • Addition of communication center on map table with seperate Circuit panel.
In the process of completing.
  • Electrical rewire.
  • Updating electronics.
  • Updating refrigeration.
  • Upgrading counters and galley.
Coyote
Sep 30, 2008
132
Great!!!!
Hey TC:
your updates and modifications look great!! good job,,,
I'd suggest, as Phil suggested in an earlier post on this subject, that you submit them to be listed on the "Owner Modification" page for the OD 28,, as I did,,,
one of mine is currently listed, and I submitted another 3 for his consideration and approval,,,
that entire section is an outstanding resource for owners looking for
information and inspiration!!
cheers,
Coyote
