What makes them a Legend?
561
J-Boat J/99 Cobourg
I see several models that share a Legend designation, and I think Hunter calls themselves Legend in Europe. What specifically made a Hunter boat a Legend model? Dan
Jun 2, 2004
5,802
Excellent question! And I hope you get the definitive answer. Our "Boat Info" is misleading I think. It has dates of '87 thru '90 for the H37 and '84-'90 for the H37.5. Can that be right? Basically it is the hull design after the Cherubinis. Look at pictures of the H26.5, the H40, the H40.5, the H37, and the H37.5. But the H40 did not have a walk-thru transom. I used to think it was just the ".5" boats but that is obviously incorrect. Of course in Europe all the boats are Legends, simply the manufacturers name.
Jul 1, 2004
567
Hunter 40 St. Petersburg
Anthem is a 1985 Hunter 40
Early on I had heard of it referred to as a "Legend."
I bought Anthem from the original owner and have the original sales brochure for this particular model and nowhere is there any mention of the Legend model designation. I have the 1985 owners manual which covers the 20, 22, 27, 34, 37 and 40. There is no mention of Legend in it either.
I can't answer your question but apparently it's a designation on later models (in addition to the whole England thing.)
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
89-94 in the 35.5 models were "Legend" series boats. I think you're on to something with the ".5" designation. There were 28.5, 33.5, 35.5, 37.5, 40.5 models for sure, ALL called Legend series boats, mostly from 89-94 time frame, and in my opinion, some of the best boats Hunter ever built. Earlier model 33, 35, 37, and 40 were NOT "Legend" series. Where's Jim Bohart when you need him?
Aug 2, 2010
561
J-Boat J/99 Cobourg
I have a scan of the original brochure for the Hunter 37 from 88 or 89 and it calls this boat a Legend 37 and references the Legend name in several places. My original question was to find out if the Legends were somehow different from the rest of the line, like the Visions are different in the style of rigging they use.
I know there are several models including the 35, 35.5, 37, 37.5 often referred to as Legends, but the only one on the Hunter website listed as a Legend is the 37. Having said that, they don't even refer to the 35 or the 35.5, perhaps because they don't have copies of the original brochures.
Still looking for an answer if anyone has one! Dan
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Add the 30' 88-94 in the Legend series.
Jun 16, 2004
37
- - Serene Zelda, Irvington, VA
Mine is a 1988 Hunter Legend 37. It has "Legend" printed on the side near the aft end and the original owner's manual uses that term. I also have an original sales brochure for the same boat from 1987 (first year for this hull with winged keel) and it calls it a Legend. Only diff between 87 and 88 is slight change in setee on starboard side to remove a table section that broke the seating area and differnt painting on cabin top. I'm pretty sure thatthe 35's those years with winged keels were also Legends. I think the Legends tended to be lighter weight and slightly more performance oriented than some ofthe other (and earlier) models, but the bigger boats that emphasized luxury were identified as Passage models. The 37 legends like mine (before the B&R rig and step up to 37.5) are among the fastest (for their class/size) boats that Hunter ever made. In about 90 they changed interior configuration by changing from foe&aft mounted rear berth to cross-wise which I like less, but hull and rig remained same. the change to the 37.5 came next and it is not quite as speedy but does have some more "creature comfort" pluses. For me, the old 37 is perfect: A true Legend!
Dec 2, 1999
15,184
Because Hunter said so.
The Legend series started with the H'35, H'37 etc and appears to have continued through the ".5" series.
The boats after the Cherubini's were NOT Legend's except in the minds of us owners!
The Hunter B & R Rig was started with the boats in 1983 or so (31, 34 & 40).
Aug 2, 2010
561
J-Boat J/99 Cobourg
Well Everybody, it appears that there is no particular reason they are called Legends other than a choice made by Hunter.
I understand the 35(.5) Legend was created for a racing series, could it have been the first of the series?
Dan
Dec 7, 2007
16
Hunter Legend 35 DeGray Lake, Arkadelphia, Arkansas
RE: Legend...
Let's not leave out our '87 thru '89 model years of the 35 Legend series!
wegu
Nov 29, 2010
11
hunter 40.5 greece
legends and hunters
When hunter began having sales sucesses in england/europe the fun started because there was already an english boatbuilding firm called hunter,thus the name legend to differentiate.The british firm still builds very good ``get you home boats`` today.I am a brit,live in germany and have an American hunter 40.5 in Greece
Sep 13, 2010
3
hunter 34 port grimaurd. south france
hunter legend
I live in England and you are right we have a boatbuilder called Hunter and i own a Hunter Legend 34 1983 and totaly agree with what you are saying.
Jan 10, 2011
20
Hunter 36 Chichester
Hi all, I too am a UK resident with a 2004 'Legend' 36. Everything said so far about differentiation from the British Hunter boat manufacturer is correct. Also worth noting that Hunter had a manufacturing facility in Portland, Dorset (UK) and all boats which emerged from this factory (like mine) carried the 'Legend' designation. Sadly this factory closed a few short years ago, and even though the ones we get here are manufactured by Luhrs in Alachua Fl, they still are marketed as 'Legend' in UK
Feb 17, 2008
144
Hunter 36 Kristiansund N, Norway
But in Norway they always has been Hunters. Even if they were built in UK.
Iain
Jul 26, 2010
8
Hunter 26 Windermere, CUMBRIA, United Kingdom
I was always led to believe that because there was already an established but quite separate boat making firm called "Hunter" already operating here in the UK, the USA based firm called "Hunter" marketed their boats in the UK as "Hunter Legends" to avoid a law suit and confusion over here in the UK.
Best wishes,
Dr. Iain Jennings owner of a Hunter (Legend ) 26
called "Eisbar"
PS I am looking to get in touch with other people in hte UK who own and sail Hunter 26's
Jan 10, 2011
20
Hi
Checkout www.legendowners.com a website for hunter legends in UK. We have regional groups around UK too, offer discounts, a very active forum full of technical advice and details of meet ups, etc... Enjoy!
Iain
Jul 26, 2010
8
Many thanks for the link to the website Scallywag-136. That's most helpful.
Happy sailing !
Jan 10, 2011
20
Careful, we've got Obama visiting us currently, we may keep him and you can have David bloody Cameron in his place!
