would someone be able to tell me what make this engine is. it is on a 44ft peterson 1977. thank you
Awesome, thank you. Yeah ive read these diesel's can sometimes fire right up after sitting. Are you saying to take the belt off the engine?Check the oil and change the fuel filters. Also check the impeller, they can develop a set in the vanes when left for long periods of time. I have a 3JH2e which is the 3 cylinder version of the JH series. It looks like there is an engine driven compressor, make sure the compressor hasn't seized. I might take the belt off of it the first time the engine is started.
And while you are there check the other belt for wear and glazing.Belt off the engine driven refrig compressor in the bottom right of your picture..
Ok yeah so I disable the compressor. Thank youBelt off the engine driven refrig compressor in the bottom right of your picture..
Thank you. Yes I will check that as wellAnd while you are there check the other belt for wear and glazing.
Perfect for picking up those pesky metal shavings.Hey this one has a vacuum attachment! More engines should come with this!
One design flaw in this engine is the crankcase ventilation. The hose attaches to the air filter and in theory the oil is sucked into the engine and burned. In reality, it just doesn't suck quite enough so some oil mist come out of the air filter and lubricates the engine room. The engineers almost got it right, it is just an invisible mist that lightly coats everything leaving you to wonder where the oil leak is.Hey this one has a vacuum attachment! More engines should come with this!
That's a shame - I have one of these in the crankcase vent hose to the filter, I get about a tablespoon every 50 hours in it. maybe it would help: JEGS 52205: Air Oil & Water Separator [4 1/2 in. Height x 1 3/4 in. Diameter] - JEGSOne design flaw in this engine is the crankcase ventilation. The hose attaches to the air filter and in theory the oil is sucked into the engine and burned. In reality, it just doesn't suck quite enough so some oil mist come out of the air filter and lubricates the engine room. The engineers almost got it right, it is just an invisible mist that lightly coats everything leaving you to wonder where the oil leak is.
My marine mechanic said it works best when you throw some nuts and bolts and saltwater in the mixPerfect for picking up those pesky metal shavings.
