what make engine?
Jan 7, 2011
5,492
Oday 322 East Chicago, IN
4 cylinder Yanmar is my guess, but not sure of the model.
I don’t see a turbo.
Any idea if it is original or has it been repowered?
There should be a badge plate on the engine.
something like this..
Greg
Likes: khodgesj90
Jan 7, 2011
5,492
I don’t see a 4 cylinder engine available in the 70’s
Here is a nice list of Yanmar engine history…
I think it must have been repowered at some point…
Greg
Nov 22, 2023
7
kelly peterson 44 sarasota
Thanks you guys. Yes after doing some research it looks to be a yanmar 4jh2e. Its been sitting on the hard for 3 years. The motor ran before it sat. Just trying to look around at what needs to be done to get it running
Check the oil and change the fuel filters. Also check the impeller, they can develop a set in the vanes when left for long periods of time. I have a 3JH2e which is the 3 cylinder version of the JH series. It looks like there is an engine driven compressor, make sure the compressor hasn't seized. I might take the belt off of it the first time the engine is started.
Likes: khodgesj90
Nov 22, 2023
7
Awesome, thank you. Yeah ive read these diesel's can sometimes fire right up after sitting. Are you saying to take the belt off the engine?
Hey this one has a vacuum attachment! More engines should come with this! :facepalm:;)
One design flaw in this engine is the crankcase ventilation. The hose attaches to the air filter and in theory the oil is sucked into the engine and burned. In reality, it just doesn't suck quite enough so some oil mist come out of the air filter and lubricates the engine room. The engineers almost got it right, it is just an invisible mist that lightly coats everything leaving you to wonder where the oil leak is.
dmax
Jul 29, 2018
1,164
Telstar 28 Buzzards Bay
That's a shame - I have one of these in the crankcase vent hose to the filter, I get about a tablespoon every 50 hours in it. maybe it would help: JEGS 52205: Air Oil & Water Separator [4 1/2 in. Height x 1 3/4 in. Diameter] - JEGS
Aug 11, 2011
958
O'day 30 313 Georgetown MD
Previously posted:
I've been contemplating installing a K&N filter on my air intake manifold, but customizing the top plate using a 3/8 threaded x 3/8 barbed elbow to attach the breather hose to the filter for direct flow.
