Maybe it is just meant to be a cover for a hole that was made for whatever reason. It obviously needs replacing so take it out and see what exactly is underneath and if some work was done there.
That sucker'll hold LOTS of milk for the cereal.Well, I finally got a chance to take the plate all the way off. Turns out that the bottom of it IS the top of the ballast tank.
Only because there were no cereal eaters in the factory....they were not factory installed.
If that's the case, it would seem several people made the same mistake in the same spot. See the two pic's I posted above, and there's more. I wonder if a dealer was installing those for some reason. I'm really curious. Maybe this is some great option I don't know I want yet.Maybe you guys are overthinking this, supposing it had a purpose onto itself.
Maybe for whatever reason a PO needed to drill an access hole in the floor or cover some damage, and used that plug as the most convent way to cover it up.
Occam would suggest so.
