Which specific hot dipped galvanized swivel did you get from Defender (I assume 3/8")? I've looked over their website and am unable to find such a model. Does it swivel well, or does it tend to bind?
It swivels well, does not bind. Here is part of an article that I wrote awhile ago about the new swivel.
"Brought the anchor, swivel and shackle home yesterday after changing the oil in both engines, so that I could get a better read on the various components. A bit of a struggle removing the frozen pin from the shackle. Some WD-40, a hammer and a large wrench did the trick. So what I actually have is a 3/8" swivel, not 5/16". Time to also replace the shackle, which is also 3/8". Both have a 2,200 pound working load. Titan out of Canada makes the shackle and Chicago Hardware makes the swivel. Both are drop forged, heat treated and hot dipped galvanized. I trust Canadian made products. Hopefully, Defender will refund the 5/16" swivel."
Here is a link to the 3/8" shackle:
TITAN Screw Pin Bow / Anchor Shackle - 3/8"
Here is a link to the 3/8" swivel:
Chicago Hardware Jaw To Eye Swivel - 3/8"
Chicago Hardware manufactures USA made products. I've only anchored a few times with the new shackle/swivel, so hard to tell how well they hold up to corrosion, but so far look like new after a few anchorings. The 2,200 pound working load is sufficient for our boat in most all weather conditions, which is about half the breaking load.
The original 3/8' shackle/swivel show no signs of stress, even after weathering some pretty strong winds at anchor; just normal wear and some surface corrosion after almost twenty years of use.
Defender did give me credit for the swivel that I returned. Nice company to do business with.
The shackle/swivel below still had some service life, but opted to replace. The pin that connects to the chain link had the most wear, albeit very little, but felt it was time to replace.
You can see that the swivel pin is somewhat worn from long term use. Although it has the appearance of corrosion, most of it is superficial.
