westerbeke b30 vibrations @low revs
Guan
Jul 18, 2011
138
Beneteau Oceanis 361 Vancouver
sorry if this is old discussion.
As newbie I need advice from those experienced guys!"
My B361 westerbeke 1650hrs vibrates severely at below 900 n smooths out instantly above 900-1000.
Can or should idling be set at 900 and above?
thanks.
Hunter 37 C sloop Punta Gorda FL
Will work. May be hard on your transmission in the long run. Why not just move the throttle up in neutral, throttle down to shift, throttle up in gear?
Feb 6, 1998
11,771
The idle speed range for the Westerbeke 20B Two and 30B Three are 1000-1200 RPM. Any lower than 1000 and you can run a higher risk of damper plate damage...
bshock
Jan 18, 2013
126
Beneteau 361 Sandusky Harbor Marina
I can confirm what Maine Sail says. I had this same concern a couple months ago with my new-to-me B361. If you look at the Westerbeke manual, it shows an idle speed setting of 1,000 - 1,200.
