Has anyone seen a rope clutch like this before? This is under the forward end of my boom and controls the out haul and jiffy reef lines. It includes sheaves to turn the line down to a small winch on the mast below the boom. A couple of the cams are corroded to the shaft, and it generally does not work all that well. If I take it all apart and clean it up and lube the pivots, is it going to be ok, or should I be thinking 'upgrade'.
