Waterproofing prior to painting
492
Oday 222 Mt. Pleasant, SC
I am stripping all things off the boat preparing it for paint. It's probably going to take me several weeks to finish stripping, sanding, repairing deck hardware holes, and painting before I'm ready to put deck hardware back on the boat. What have people been doing to seal up the hardware holes prior to working? I'm thinking just some clear packing tape since it's probably going to more watertight than the hardware that's on there right now. Any suggestions? I'd rather not tarp it since I know I'm wearing my neighbor's patience thin as it is right now.
Jun 2, 2004
5,802
Duct tape.
The real stuff, silver with a peel-off paper backing. I find that it really seals and does not leave a glue residue like the gray tape that some people call duct tape. When I had my portlights out I used it with clear painter's tarp cut to fit the cutout. Not a drop of rain came into the cabin. And I still had plenty of natural light for inside work.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
I think Ed...
is on to something! You can get that at HD I think. The shiny silver foil with pull off backing... for ductwork... or aluminum faced insulation. I learn something new every day here.
Mar 31, 2007
59
- - SF Bay
Why do you need to do that?
If you are expecting rain or heavy dew, then cover the boat with plastic and tarps. Blue tape is ok for masking of wood that you don't want paint on. if paint gets in the screw holes it'll make the screw hold better, especially if it's polyurethane. You want the surface you are going to paint to stay as dry as possible.
Oct 10, 2006
492
Neighbors
Thanks Ed, I've got some of that tape. I remember reading something about ductwork and tape that was acceptable to use. Turns out that almost any other kind of tape worked better than the stuff typically called "duct tape". Like I said, I'd use a tarp if I was sure my patience wasn't wearing thin with the neighbors. I think the real duct tape might work out fine.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Sealant
we just put a small blob of silicone in the holes and plucked them out when we were ready to put back together. Good luck
