Hi All,
I have removed the "Garelick" Outboard motor Bracket because the previous installation was incorrect in every respect. The mount was incorrectly assembled and required a stack of wedge shaped plywood pieces to get the mount to sit plumb on the transom and plain steel bolts were used which are now heavily rusted and the wood is rotten. My plan is to repair the previous drillings and secure a 12" square piece of G-10 fiberglass board to the inside of the Transom. My actual question is where is the waterline on my 1977 O'Day 22 ? The Honda 4 stroke manual I have states that the anti cavitation plate needs to be 4" below the waters surface and the Garelick has what I measured as a 8" range of motion up and down. Before I place the new bolts for the motor mount I want to be confident I'm at the right height. There is a Blue stripe painted on the Hull down low that is a couple of inches wide. Is this the actual waterline? Should I do something else to determine the height of my engine?
