I find what seems to be fresh water in my bilge and surrounding compartments. While they are linked with channels, I can't find the entry point. Checked HW heater, see nothing. Thoughts?
Thanks, Yes, moored in salt water...I think too much water for condensation.You are moored on saltwater?
A large cold front just passed, with a huge temperature drop, maybe condensation?
Wash thoroughly with a hose and look for deck leaks from there.
-Will (Dragonfly)
Moring Will,Because of the structure of Beneteau’s hull and liner arrangement, it’s really hard to figure out where water comes in from until it emerges under the liner in the bilge. Water can also hide under the liner until the boat moves enough to make it run out. How often does the water seem to emerge and how much of it? Are the water tanks full?
Morning Dave....Moring Will,
The hull and liner arrangement does present some challenges. I can tell you that the last 2 times we sailed, I had a small amount of water under my engine battery box, completely separate from the rest of the liner, I think that is a drain issue from the fridge. The rest of the liner has about 1/4" or less in some of the liner areas, more towards the aft..... I know the boat went in dry, I clean out the bilge and liner each winter before storage. Never a big amount of water, just annoying...and frankly, should not be there. Your thoughts are appreciated....
Many have used talcum powder to better track and chase leaks.
Thanks for the tip....I am off this morning to investigate. If J&J stops making talcum powder, it sounds like an opportunity to invent a substitute, label it "marine" and make a fortune...... Also, is the anchor locker drain blocked, causing overflow back into the cabin? AND, I heard J&J is going to quit making talcum powder.
