Water tank leakage - Oday 34
Oday 272 Charlotte/Lake Norman
Pat, I experienced a 12" crack in my 272 water tank last November (above) and tried A LOT of different ways to fix the problem. Long story short, I had no success and getting a flex tank was not what I really wanted to use as a solution...until I discovered hot air welding. There was no one in the Charlotte area doing this sort of repair that I could find, but I did stumble upon an hot air tool distributor in my area. Although he was not set up to do repairs, he agreed to take a stab at my problem and show me how it works. After he cleaned up the mess I left behind and used the hot air welder to fill the crack, it turned out perfect. Plus, the $75 he charged me was far less expensive than buying a new flex tank. I've since found out that some plumbers do hot air welding on plastic piping, tanks, etc. so you just have to dig and find one that can do it. In my case, a little extra diligence paid off.
beilts
Jun 14, 2004
17
Oday 34 Mandeville, LA
Congrats, looks like you found the source of the leak. Thanks for the pics. It gives me some ideas. Looks like you have a hot water and cold water foot pump? Which raises a bunch of questions concerning how that works with the electric system. Must be a bunch of hoses.
Not hot and cold. There is a saltwater and freshwater. The saltwater has its own thruhull. As I said, I am not sure where the freshwater hose arises. The foot pumps are very handy though.
May 30, 2006
365
Oday 34 Chesapeake Bay
Ok, that makes sense. Karma has a thruhull for the same purpose (raw water supply), however the pump is a hand pump above the sink. I got it working once when I had the sink out, but it failed again within a few weeks. When researching a replacement, I discovered that the pump was for freshwater systems only, which explains its abbreviated live. I've had installing a foot pump on the list for several years, but never got around to it.
Pat
Jun 7, 2004
1,250
Thank you...I had not tried to find a person who could repair...it is white polyethelene....the crack is so hairline just below the top edge just below the top....actually...the tank does come out...I'll for sure check around.
thanks, Pat
