Okay, Another question from a newbie: I have an 1987 27'. I purchased it late in the season last year. To winterize the water system I drained it and poured in 8 gallons of anti freeze so that it filled up the hot water tank also.
fast froward to spring - opened the boat, put the batteries in and the water pump came up to pressure fine. I started to drain the anti freeze and catch it for re-use but after I caught two gallons the pump seemed to loose its prime. It just kept running and I had no water pressure. I dumped a gallon back into the tank and the pump primed. I started draining again and the pump lost its prime again after I got another gallon.
I didn't want to put water in the tank to flush it because I want to reuse the anti freeze. This is the first time I am getting the boat out of winterization and I feel I'm just missing something. Any Help? Thanks
