Water Standing Under V Berth
Jun 20, 2021
53
Catalina '83 30 SR Universal 5411 Arkansas River>Caribbean
I drained the fresh water tank into the hull. Is there a drain to let water from this area into the bilge? I couldn't find one.
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Not sure what you were trying to do. I generally use the fresh water pump to empty the water tank into the sink, and out of the boat.
Did something fail (a water hose)?
Greg
Jun 20, 2021
53
I siphoned the water into the bilge to remove it. I was replumbing the boat.
Thanks for the replies.
Feb 18, 2022
440
Catalina 36 Port Orchard
How goes the progress on replumbing the boat? What are you using for pipe/hose and fittings?
Jun 20, 2021
53
I
The pressure side is finished. I have one drain and the holding tank vent left to replace.
The pressure side is all PEX. Drains and vents are nylon reinforced vinyl tubing.
Feb 18, 2022
440
I
Got some pics to go with? I would love to see how it turns out. If you have seen any of my pics of Luna in this forum, you will see I need to do much of the same for her.
Jun 20, 2021
53
No pictures. It's mostly in the bilge area.
  • Wow
Likes: mikeracca
