Water Pump Location
7
Hunter 33 Cheribini Lake Texoma Grandpappymarina
Can anyone tell me where the water pump is located on my 1980 Cheribini?
Jun 21, 2007
2,117
What engine do you have? Then I can look at my manuals for the various Yanmar models. Hunter did vary the engines. Depending if you have a strictly raw water (sea water cooling only with no heat exchanger), or a OEM fresh water (self contained with anti-freeze and also sea water cooled both routed through a heat exchanger), or a raw water model that has been converted to a fresh water, the location and purpose of the pumps will be different. If you are new to your boat and the engine, possibly determining the engine model isn't obvious. Either on the left or right side will be an engine nameplate. Sometimes hard to find because of tight bulkheads. Taking/posting some pictures will be helpful. Let us know!
May 27, 2004
2,057
I think the OP means the pressure water pump for sink, otherwise may I suggest a diesel mech course?
Jun 25, 2009
542
Hunter 33 Seabrooke, Houston
In my boat the pump is uder the starboard lazarette, under a cover, in front of the waste bladder bag
But a friend, with a similar boat, has his pump located under the head sibk, starboard, right in front of you when you open the 2 access doors
JimBr
Dec 28, 2007
49
Hunter 37-C Grand River, OH
Mine is 1980, hull 143. The water pump is under the galley sink, outboard.
Sep 22, 2009
84
Hunter 33 1980 Kingston
I've redone all the plumbing on my 33 this year. I decided to relocate the pump from the starboard cockpit locker to the head. The locker was cluttered with tees and the pump would sit in water if any leak happened. Of course, I had a bunch of leaks.
I figured I'd mount the pump on the cabinet structure but the noise from the electric pump resonated throughout the whole vessel. I resolved this by mounting a small piece of plywood to the hull with some thermoplastic urethane which absorbs the vibrations and noise of the pump. I also installed some bleed valves to help with drainage before the winter.
bgrube
Mar 12, 2009
12
Pearson 365 Ketch Holiday Hill Marina, Mayo, MD
In my 1980 30 it's under the quarter berth with the electrical distribution panel which I've always thought was a really stupid place.
Feb 14, 2010
156
Hunter H33C Quincy, MA
fresh water pump mounting
I have a 1981 33', ripped out the fresh water system during the course of a holding tank install. . . I haven't reinstalled the fresh water, and was wondering how long you've had the pump in the new location and how things are workin' out. . . thanks
Aug 23, 2009
361
Hunter 30 Middle River MD
My 77 30 has it under the starboard settee about half way to the tank from the front. Only problem with the location is it does make the space around it less than usage. Also it's not far from the house battery bank which isn't great if it springs a link.
