Water pump housing
Oday 272LE Coldwater Lake Michigan MI
I just replaced my impeller on a Universal Model M-12. I noticed a small hole in the housing near the botom mounting bolt that has a slight drip. The hole doesn't really look like a pin hole but could be easily repaired. However it really looks like it has always been there. Is this possibly a weep hole or a screw missing? Does anyone have any input?
Thanks,
Ron
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I am not familiar with the engine, but I have never heard of a weep hole in a water pump - but maybe it is supposed to be there. Be interesting to watch this thread.
Nov 6, 2006
10,253
There usually is a weep hole or an opening in the pump case just behind the seal.. It tells you that it is time to change the seal before the leak gets bad enough to let water get back to the bearings and/or into the engine. Sounds like it is time to change your seal.. check the shaft for wear where the seal rides while you are rebuilding .. Good Luck with it, Ron.
Mar 6, 2008
1,525
See the link below and you may consider replacing the Sherwood pump with the Oberdorfer pump. Some modification is required depending on the type of Universal you have.
Installing a new Oberdorfer was not so complicated.
Thanks to many help received from this forum members and experts.
http://biax.selfip.com/OberdorferRaw...e-FrameSet.htm
Sep 6, 2011
82
Oday 322 Hawkestone YC Lake Simcoe
Most automotive type pumps I have seen have the hole there as a tell that the pump ios starting to fail at the seal and may need replacing soon.
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
My Sherwood pump has a weephole between the water seal and the oil seal. If water is dripping out, then your water seal is worn and needs replacing.
