So...
Our fresh water pump gave up. It would continually run and not build pressure. Looked to be pretty old so we replaced with a new Shurflo, pretty straight forward plug and play.
Now the issue; the new pump builds pressure but cycles about every 4-5 minutes as if the system is loosing pressure. I've checked for leaks and found none.
Also, the hot water pressure is not as it once was, starts out normal then slowly reduces to a trickle while the pump is running constantly.
Clogged/blocked hot water heater? Everything worked fine before the pump failed.
Thanks!
Thanks!
