- Oct 22, 2014
- 24,519
I have a mysterious water leak that has filled a small compartment that contains my 2 thru hull ball valves. At first I worried that one of the valves was leaking. Our recent time on the hard affirmed the thru hulls are leak free.
The water is coming in from some other source. Suspicion is now from the sink or a drain fitting.
Anyone know of a non staining dye product I could use to locate the leaks source.
Thanks for your ideas.
