Water leaks
I have a mysterious water leak that has filled a small compartment that contains my 2 thru hull ball valves. At first I worried that one of the valves was leaking. Our recent time on the hard affirmed the thru hulls are leak free.
The water is coming in from some other source. Suspicion is now from the sink or a drain fitting.
Anyone know of a non staining dye product I could use to locate the leaks source.
Thanks for your ideas.
Hmmmm
Not strictly non-staining but regular food coloring can be later treated with mild bleach and the stain would be removed.
All I got.
de nada
use red... it is already absorbing in the blue range and the bleach will remove the pi-bonds shifting the absorption into the UV. So you can't see it anymore. If you go with blue you have a chance of a yellow hue remaining.
That is good info. Magic through science.
Why not just use something like orange juice? No staining. Or some of that lousy US beer?
AXEL
Mar 12, 2008
359
Catalina C30 MKIII WEST ISLIP, NY
Dry the entire area. Lay some newspaper all around the area where the leak is suspected. Come back at a later time and follow the wet spot on the paper to the source. I have used this method many successful times.
James... I could smell that one coming..
Beer would be wasteful
Aug 13, 2012
533
Catalina 270 Ottawa
A trick someone came up with is to use a water soluble marker. Mark around the area and you would see from where the water is coming.
859
Catalina 22 Minnesota
Best one I heard was using sidewalk Chalk. Color the bilge or compartment area and then use the sink. The chalk will disappear when it come in contact with water making tracking the leak easy to find.
ToddS
Sep 11, 2017
248
Beneteau 373 Cape Cod
+1 for sidewalk chalk... I've done that... or (depending on the surface, and location) surrounding the area with strategically-laid out toilet paper also works... come back later and some of the TP will be wet, or semi-dissolved and point you in the right direction... T.P. isn't necessarily better than chalk (or markers), but it is more likely that you already have it on your boat.
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
In a very hard to see location, I put a white cloth "hand towel", then poured 3 gallons of colored water around the suspected leak areas.
The towel showed a small stain where the leak was.;)
Jim...
We chemists prefer the terminology "better living through chemistry".
Still trying to shed that alchemy stigma, huh? Here's a tip, stop trying to turn lead into gold. :p
- Will (Dragonfly)
