I found the oil pan full of clear water after two weeks with engine idle. It is a universal 18 diesel. Any idea where this is coming from. The anti freeze that I use for the cooling system is dyed so I do not think that this is the source.
Could be a siphon event. Do you have a siphon break in the wet exhaust injection hose? Do you close the engine seacock?I found the oil pan full of clear water after two weeks with engine idle. It is a universal 18 diesel. Any idea where this is coming from. The anti freeze that I use for the cooling system is dyed so I do not think that this is the source.
I do not have a siphon but rather an 1 1/4 check valve. I do not normally close the engine seacock but I did after the last event. The boat is a 1980 catalina with a universal m18 engine (1985). One possible reason, I've just been told, could be that there is a problem with the exhaust el where the fresh water and exhaust are mixed and that if there is infliltration of sea water into the exhaust manifold it could make its way back to the exhaust manifold, down to the valves, leak to the cylinders, drip down the sides and mix with the oil. Is this possible?Could be a siphon event. Do you have a siphon break in the wet exhaust injection hose? Do you close the engine seacock?
With a little more info about the boat/engine/set up we may be able to guide you in a better direction.
Yes it is possible. This is a siphon break, others may look slightly different. If you have one it may have become clogged and allowed a siphon and if you don't have one you might want to look into one.One possible reason, I've just been told, could be that there is a problem with the exhaust el where the fresh water and exhaust are mixed and that if there is infliltration of sea water into the exhaust manifold it could make its way back to the exhaust manifold, down to the valves, leak to the cylinders, drip down the sides and mix with the oil. Is this possible?
