water in the watertight bulkhead
Jon
I geting water in the watertight part of the hull of my 1975 daysailer '17. I'm sure it's not the drain plug, or either of the circular hatchcovers in the cockpit deck. Should I suspect the centerboard housing, and if so, is the a common problem with a common fix? Many thanks.
May 31, 2004
858
Catalina 28 Branford
As gross as this sounds....
give it a taste. If its salt water, then your centerboard trunk is a suspect. If its fresh, then its rainwater. If you have eliminated certain possibilities from the deck, try others: chainplates; mast step; cleats, stanchions, pulpits, etc. You can selectively apply a hose to just the suspect areas for a check.
ed21
Jun 7, 2004
55
- - baltimore, md
CB a good guess
If it looks like bilgewater, smells like bilgewater & comes from the bilge.... I ain't tasting it! :)
Roger
fix your leak with my book
Check the Daysailer II book topic and follow the links to my book. It will tell you how to fix most of the leaks on your daysailer. CB pivot bolt is only one of a number of places that design features on the daysailer faciliate water coming in, whether its rainwater or seawater. (Unfortunately, it is usually a combination of both)
