Warning about the wet bilge
I recently conquered the "leaks" problem, but the wet bilge maintained by the previous owner had repercussions.First, if you are finding water pooling aft of the drive shaft, there is a good chance your cockpit drain hoses have gotten old and cracked. I would check these out.Second, I wanted to give you a heads up on the impact of the wet bilge. There is a block of wood at the front of the bilge supporting the compression post thru the cabin to the mast step. This block is encased in fibreglass, but there was a crack in the fibreglass and the block of wood started to rot. Now my deck has compressed, and I will have to replace the wood during layup this winter.Keep the bilge dry, and make sure this block is protected from the water, and you will avoid this repair.Good luck with the search for leaks.Ed#4900
