Hello, I keep having water in the bilge of a 1984 Oday Daysailer II we purchased a year ago. It had two small holes on the bottom hull close to the stern, one on each side about 3-4" from the center of the hull on both port and starboard sides, and same distance or a little more from the transom. I installed an inspection port in the back sole near the transom and dried the bilge out (I thought so) and left it open for 5 months covered with a cloth to avoid insects, etc., while I was gone for 5 month. I also covered the sailboat with a tarp to protect from rain, etc. At that time I patched the small holes and left the bilge drain open.
My guess is that the foam used for flotation is soaked. Can anyone confirm this and advise how to dry it out better, or will it need to be replaced? Every time I lift the bow higher, water continues to trickle down to the transom. I would love to see a color photograph of how the foam looks inside the bilge. Thank you for your help!
