Water heater thermostatic mixing valve
Nov 16, 2012
1,055
Has anyone added a thermostatic mixing valve to their hot water heater? Because there's no adjustable thermostat on the HHW it comes out really hot at times. Seems like something like this would work well:
http://smile.amazon.com/LightInTheBox-Thermostatic-Mixing-Valve-PHW-02/dp/B00ATLZUCI
At the dock we are plugged into AC to keep the battery charger going and reefer cold. Our AC panel only has breakers, no switches (another upgrade project ahead of me), so I can't turn the HHW off, unfortunately.
Sure, Rob. Maine Sail has written about this many, many times. Search here on "Honeywell" for starters. Your choice is good, too.
But I find it hard to believe you don't have a water heater switch on you AC side. Our boat is much older than yours and we have one.
Nov 16, 2012
1,055
The DC side of the panel has switches (and push button breakers), but the AC is only push button breakers. Not sure why Seaward/Catalina did that. I've got a new panel ready to go, just not a block of time to install it; plus it has larger studs for the battery cables so I've got to either drill out the old ones (not a good solution, I know), install new lugs (may not be enough length to do that), or run new cables (serious work!).
Catalina 310 #147 Oakville Yacht Squadron
just received this Honeywell for installation this spring. $60CDN @ Home Depot, cheaper in the US. Lot more variety in the US as well.
Peter
Nov 16, 2012
1,055
Still works as a shut off, no?
Unfortunately no. They have the same breakers on the AC and DC, but only the DC has switches. The only AC switch is all or nothing. Bad design.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
how do you disarm the device for servicing if there is no switch
Nov 16, 2012
1,055
Turn off the main AC 30A breaker. But that means they all go down: charger, water heater, AC outlets. Kind of a pain. Thus my desire to install the new panel. Actually I've discnnected the wires from the breakers now and then to work on the devices and keep the other AC circuits alive. Just have to be very, very careful working with hot circuits.
Beneteau 323 Annapolis MD
I find it hard to believe there is not a thermostat under the cover where your 110 connects. Probably a thermal reset button, too.
RoyS
Jun 3, 2012
1,742
With regard to your mixing valve photo: Honeywell has the same mixing valve available with threaded connections instead of the sweat fittings on the one shown. Try Pex Supply on the net. Some mixing valves require a fairly large flow rate to work, so I would avoid those.
Blitz
Jul 10, 2007
724
Seidelmann 34 Atlantic Highlands, NJ
Seems very odd with how it is wired. Hope you realize that if you don't have water in your hot water heater you can never turn on your main breaker.
Having a mixing valve is a safety item if you have kids or those not familiar with your boat - to prevent scalding. I personally just blend but my water heater thermostat is never high enough to scald anyone.
I think a bigger safety item would be to have your panel wired correctly. I think the first priority would be to adjust your thermostat on your hot water heater first, then replace the panel or correct the wiring system when you can. The mixing valve can always be done later.
Deleted member 117556
I only leave the HWH for about an hour and then shut it off. Water stays hot for a couple days so I also do not understand the need for a thermostat. My boat is also a 2000 C-310
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
to keep the water temp lower than scalding ....if you have children or grand children you will understand
Nov 16, 2012
1,055
The water heater does have a thermostat and thermal reset under the cover. But the thermostat is fixed. The problem comes when engine cooling water is used to heat the hot water-there's no thermostat control for that, so the how water can get very hot.
Nov 16, 2012
1,055
There is a thermostat, but it is not adjustable, nor is there temperature control when the engine cooling water is used to heat the hot water. The mixing valve is the only way to control the temperature of the hot water in the boat.
The panel is wired correctly, it just doesn't have switches for the individual AC circuits, only breakers that's can't be turned off. I do plan to replace the panel, but more for convenience than safety, including having AC outlets when the water heater is empty.
Nov 16, 2012
1,055
Rob, maybe I'm not making myself clear. That IS the shutoff switch. I do not understand why you're doing this.
Here's a picture of our panel. AC main breaker (1986 single pole) and the water heater pushbutton switch below it.
http://c34.org/bbs/index.php/topic,2620.msg13781.html#msg13781
No picture. I've got a similar 30A master breaker, but the individual breakers can only be reset when they trip; no on/off function. On the DC side it uses the same breakers, but with switches on the side.
