Water Based Antifouling
Dec 11, 2015
319
Hunter 25 Plymouth
Need your wisdom, can an oil based antifouling be painted over by a water based AF paint? Also, any experience/anecdotes about water based AF? Thank you!
961
Macgregor & Island Packet VENTURE 25 & IP-38 NORTH EAST, MD
Just did the bottom 2 weeks ago with Hydrocoat. It rolled on super easy, coverage was as advertised, no strong/bad odor and it washed off with soap and water. I like the fact it doesn't need to be sanded before recoating. Hopefully its antifouling properties are as good. Will know in the fall.
Likes: rgranger
The only real complaint I’ve heard of Hydrocoat is that as it wears it becomes draggy and slow, even if kept clean. I did hear it from a racer who usually uses the super smooth VC-17, so his threshold for the drag of a porous paint is probably pretty low.
