Water ballast sailboat rudder uphaul lined
-na -NA Anywhere USA
It had been a long time since since installing uphaul rudder lines and I am reaching out to you for advice particularly on the 240 and 260. All I can recall there was a line tied to the rudder head to a small turning block within the rudder post.
was the block above or below the bolt inside the rudder post.
I am drawing a blank. The. Drawings are not clear. I have two inquiries both Hunter 240’s. I would appreciate any help. @caverun @rgranger @patbratton
@Teboll pictures please. Also look inside your rudder post for any turning blocks
Feb 18, 2011
331
Hunter 260 Cave Run Lake, KY
Hey Dave, the original downhaul line had a single block inside the post (near the bottom) with a 2:1 purchase. Many have upgraded to a 4:1 system using 2 double micro-blocks as explained on this web page, scroll down to the bottom section:
Hunter 260 Rudder
The Harken micro-blocks do fit inside the rudder post.
Jun 12, 2021
294
Hunter 240 Aqualand Marina, Lake Lanier
I purchased the blocks and new line for the rudder and have never gotten around to installing. I found that my rudder is water logged and I just haven't gotten around to replacing it.
Sep 30, 2016
372
Island Packet IP 44 Ventura, CA
Is this pic what your looking for Dave? This is for a H23.5. The drawing is pretty busy, but you get the idea. I never used the setup on my boat. Id just move it up and down by hand. But I normally only had to do that at the beginning and end of the season.
