want new motor for C 16
Jun 28, 2014
3
Com Pac 16 II N. Myrtle Beach, SC
Recently purchased '87 C-16 with same model Evinrude 4. It runs fine, but looking to upgrade to a 4 stroke. What suggestions do you sailing vets have as a replacement? Will be used in salt water and fresh. Thanks.
4
4 stroke
I have had two Nissan 4 hp 4 strokes. Why two you ask? First one was hit by a fisherman who lost control of his bass boat. I have had the second one since 2002. It is the same motor as the Tahutsu and Mercury. All made by Tahutsu. Runs exceptionally well. Loves to have fresh clean fuel. Starts on 1st or 2nd pull, even after sitting all winter. Flushing it frequently after salt water will prevent the usual problems as I think most small outboards are certified for salt or fresh water. My neighbor has a Yamaha 4 or 5 hp and it is also a great runner. Used on a Catalina 22. Good luck.
Sep 6, 2012
1
Com-Pac 16 Home
I use a 55-thrust 12 volt for 6 hour day sail on my 16-2. Plenty of power. Might have to use the battery max one (1) hour.
Just in case I should get to have an overnight I keep a second charged battery on board.
With my limited experience sailing the Tennessee River, if I were to plan for a several day sail I might have to include stops to recharge overnight. Enjoy your sailing. Easybreezee
Likes: JBP-PA
Nov 11, 2009
44
Pearson 365 Ketch Babylon, Long Island
Upgrade? The only upgrade I can think of going from 2-stoke to 4-stroke is an environmental upgrade. I've owned several small outboards over the years with my last experience being a new Nissan 6hp 4-stroke. The Nissan 4-stroke was fine, no problems, but my un-scientific opinion is that the horsepower is overrated compared to a 2-stroke of same HP rating. Aside from that, I found storing, handling and transporting a 4-stoke a little more of a challenge with proper positioning required so as not to have the crankcase oil leak out. You can also expect the 4-stroke of similar HP to weigh more than a comparable 2-stroke. Just my 2-cents.
Andy
4
I totally agree with Andy. Nothing wrong with a 2 stroke. They are lighter, which can be important on the back of a sailboat. The only disadvantage is the mixing gas with the oil. the other advantage a 2 stroke has, in my opinion is the larger jet size to accommodate the oil. 4 strokes have more carb problems because of the really small jet size. Just my opinion. I have a f stroke because that is what was readily available when I needed one.
4
Does any manufacture make a 2 stroke now? I had the feeling that they all went away with emission controls. Could be wrong though - will not be first or last time. LOL
Jun 28, 2014
3
Thanks for all the replies and help, guys. As luck would have it, I came across a '99 Merc (2 stroke) 4 hp that a guy just needed to get rid of. Even had long shaft. Purrs!! :)
Feelin lucky!
Maybe I need to ask for more things on here. lol
44
Al: Believe you're correct, no more new 2-strokes.
Marc: Congrats. Nice upgrade.
Andy
Jan 8, 2025
179
Compac 16 Pensacola, FL
On the ;'78 Sixteen I had I used what must be the perfect small boat engine: Mariner 2-stroke 20" shaft, air cooled, f-n-r plus 360 steering, and an alternator! I'd buy one today if I could find one still running. (Because I think a day without messing with someone's head is a day wasted, I used to start it and let it putt putt while I rigged the boat on the trailer. Pretty soon everyone around stopped what they were doing and stared, waiting for it to seize.)
Likes: JBP-PA
JBP-PA
Apr 29, 2022
831
Jeanneau Tonic 23 Erie, PA
That's not entirely fair, 2 strokes are loud, smokey, smelly, inefficient, and require adding the proper amount of oil every time you buy gas. The lighter weight and requirements to lay it down on the correct side are only relevant if you remove/remount your outboard routinely, if you leave it on all season it's insignificant.
degas
Aug 14, 2023
77
Tanzer 29 Lake Ontario
What would you be using the engine for? Getting in & out of harbour or going for longer distances?
Have you considered an electric outboard? For small boats like a 16-footer, a 1 kW electric has range and power comparable to a 2.5-3HP outboard (w/integrated tank). Electric makes even more sense when you consider maintenance and reliability.
Likes: JBP-PA
