Volvo Shaft seal
Dec 6, 2011
20
Wind Dance 39 Fort Myers Beach, FL
Anyone have experience with this leaking. I have seen it recommended to put Lithium grease under the shaft seal, and to squeeze water out of the tube but the tube is hard plastic and has not flex. .
There is a space between the plastic cap and shaft where one could sqeeze some grease in, where the shaft goes forward toward engine.
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
Leaking I would definitely pay attention to. As I understand it, the maintenance grease goes in under and just past the lip. The technique I've read about and used is to put some waterproof grease in a drinking straw then flatten one end, slide it under the lip a bit, and squeeze the grease inside.
Dec 6, 2011
20
The leak was bringing in about two or three cups of water with motoring about 1.5 hours for a few months. Now it seems to have abated down to maybe 1/16 of a cup in same period. but I will try the grease. I am due for haul out next week anyway and will be able to check it. If defective I think I will go to a PSS Dripless SS. They seem to be more highly regarded.
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
Verify if the motor mounts have not moved/misadjusted. My Volvo seal leaked about a gallon per hour after owning the boat for two seasons. On launching the next season, I found the lower nut had loosened on one rear mount. re-adjusted and problem went away.
Likes: NYSail
Feb 3, 2012
72
Corbin 39 Pilothouse Cutter Lyme, CT
Use Volvo grease, burp right after launch. The Volvo shaft seals are very reliable!
Likes: NYSail
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
As said, you have to burp the seal... not the tube. And only put a small amount of grease in... to much will clog things. I use the Volvo grease..... My boat had the original volvo seal that was 16 years old and did not drip a bit. However I had to do some work on the shaft and figured I would replace with a new volvo seal which was a breeze. They are simple and work great..... not a single drip.
Greg
Likes: BigEasy
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
I’ve been using Lubriplate 130AA to grease the seal. I use it on my Maxprop. It is waterproof. I haven’t seen it harden and haven’t had any problems.
Fluid Type: mineral
ISO Viscosity Grade of Base Oil: 150
NLGI Grade: 1
Thickener: Calcium
Food Grade - NSF H1: No
Color: Beige
Dropping Point (F°): 190
Dropping Point (C°): 88
Operating Temp Range: -15 to 170
Opinions?
Sep 24, 2021
386
Just received a couple of tubes of the Volvo grease... under $15 CDN each. Saw an Amazon seller listing same for $76/tube!??!
Sep 24, 2021
386
Thinking now that it must be a whole case of tubes for $76… doesn’t say but shipping weight (over 2kg) would indicate. Lifetime supply?
