Hello Steve and you other Vision owners.
Last weekend we did a rough passage out the gate. While mototing on the way home, spray was soaking the foredeck and the mast. Water was dripping into the V berth. I took the interior ceiling trim off from around the mast inside the V berth. Water was dripping from the ends of the bolts that bolt the ring to the deck around the mast/deck penetration. At our slip I looked closely at the topsides gasket, bolts and deck. No cracks, but it looks like the bolts had turned as there was what looked like anti sieze cream around the bolt heads in a circular pattern. I could not turn the bolts with my fingers.
Any ideas? I emailed an inquiry to Hunter Marine.
Thanks,
Mike
Thanks,
Mike
