Vision 36, leak around the mast
303
Hunter Vision-36 Richmond
Hello Steve and you other Vision owners.
Last weekend we did a rough passage out the gate. While mototing on the way home, spray was soaking the foredeck and the mast. Water was dripping into the V berth. I took the interior ceiling trim off from around the mast inside the V berth. Water was dripping from the ends of the bolts that bolt the ring to the deck around the mast/deck penetration. At our slip I looked closely at the topsides gasket, bolts and deck. No cracks, but it looks like the bolts had turned as there was what looked like anti sieze cream around the bolt heads in a circular pattern. I could not turn the bolts with my fingers.
Any ideas? I emailed an inquiry to Hunter Marine.
Thanks,
Mike
Jun 6, 2006
6,990
check the tabernackle lumber holes. The mast sits in the tabernackle and it is the tabernackle that gets bolted to the deck. If the lumber holes are clogged with bird nest flotsom or just plain dirt it fills with water and that makes its way to the bolts. The holes on mine are forward center, aft center and port and starboard about 1/4 of the length back. They are very small (1mm) so you have to look close.
Dec 2, 1999
15,184
Bill:
The Vision is a keel stepped mast (about 13" in diameter at the base).
Mike:
The best bet may be to remove the ring around the mast and check seal. Maybe a little silicone spray and retighten the bolts.
Mar 16, 2009
303
Bill:
Mike:
Steve:
If I remove that ring on top, won't the mast be free to move around? Or is there another ring that centers the mast?
Dec 2, 1999
15,184
I think there is a rubber ring that is your deck seal. You would not be removing the seal, just the bolts that hold the ring in place.
My boat came from Missouri and they took the mast out of the boat every other year.
