Ron
I recently purchased a 1982 '30. It has the 5411 diesel. In neutral it vibrates when throttled up.When motoring I have alot of vibration at almost all RPM's. Some better some worse. I know about the flange clearance from the shaft. Has anyone installed softer motor mounts or a dampining device on the shaft? The cutlass bearing is within tolerance. The motor mounts are rusty and need to be replaced. Also the shaft to flange is rusted tight, so I can't check the clearance without replacement. Any ideas????
