G
GG
Got ahold of a VHF signal strenght tester: Reace model # SWR-3. I'm really not sure how the interpret the results of the test.Type of unit comes with an input connector where your connect your antenna connector into one side and then an output on the other side where you connect your VHF. It shows you the strenght of the signal both when receiving and sending, but the actaul scale is unclear as far as extablishing what I should be looking for.Could not find anything on the web on this unit.Does anyone have a similar unit with a manual?Thanks,G
